Push Button Start in a JK - Issues
Hey Folks,
Before you roast me and ask, "Why?"...the answer would be "Just Because". I'm working on installing an aftermarket push button start in my 2014 JK. I'm doing it not for the allure of new tech, but actually for a bit of old-school uniqueness, and that's what Jeeps are all about, in my opinion. Anyway...on to the issue. I've managed to isolate the ignition 12V pink/white wire at the ignition switch harness. The ground is easy, as well (black, at harness). The wire thats eluding me is the proper starter wire. There are no wires in the steering column that measure 12V on key crank. If I connect to the violet/brown wire at the ignition harness, the starter won't even crank with the key, let alone the button. I've also run a wire to the large yellow/grey wire at the TIPM for the starter. What this ends up resulting in is starter cranking, but no actual starting (when button is pressed, and key is in the 'ON' position). I don't quite understand why sending power directly to the yellow/grey starter wire with the key in the 'ON' position doesn't result in a successful start? Also, is there not a wire in the steering column that would properly send power to the starter? I did this on my Ford Explorer, and had zero issues. Is it the CAN-BUS that's not allowing this to work on the Jeep? Any help is appreciated, Jeepers! |
maybe it thinks it is being hot wired.
Originally Posted by jadmt
(Post 4334951)
Google easyguard ec002 wrangler
