question about adding power windows...
SiliconT, I did not keep the instructions, but its extremely easy to do. The hardest part is just removing the damn door panel. Once in you just take off about 10 bolts holding the inner door panel to the door and then three bolts that hold the crank mecahnism in place. Then you just put the power unit in which is preassembled and bolt it all back up. The electric connections are pre done, and all you need to do is snake it where you want it and find a power source. Really simple.
