Question about fog light mounts
I'm planning to bu another set of fog lights. I have a rugged ridge xhd bumper with the hoop over. I want to mount the fog lights onto the hoop over. Will the rugged ridge overrider clamps work? They say they are universal. Just wanna make sure..thanks!
If you are trying to do it with a stock fogs it will not work they use 4 screws to screww into place to get the proper adjustment. If you plan on doing an aftermarket fog kit you can buy claps like these made by warn that should hold your lights in place.
WARN 85300 - WARN Industries Fixed Position Tube Light Mounts for 1.5-2" Diameter Tubing - Quadratec
Originally Posted by JK-Ford
Mounting fog lights that high up will make them useless in inclement weather.
Ok. Your starting to sound better. But, to much of a good thing is actually bad. Why do you need two sets of fogs.
