questions about triggering Off Road lights with high beam circuit
I have been reading around the site and cannot find concrete informaiton on this.
I will be running them through relays, there will be 4 55w hid hella 500s being triggered.
my mechanic said this cannot be done with the canbus system, however, i have other that said the relays dont use enough juice to worry about.
Can anyone confirm that I can infact trigger my off road/moose lights with my high beam circuit.
I can't remember the technical reason but when I had mine installed they did not want them wired to the high beams. There was a electrical reason though. Just wire them to a switch... Works great!! Sorry I could not give more detail.
Ok, so use the same diode setup I would you to keep the hid headlights from flickering. I want my aux lights on the high beam trigger because it's a pain to be hitting a bunch of switches on the highway. Rather just have them trigger via high beam.
The capacitor circuit would smooth out the relay. The power for the lamps should be coming from the battery ( clean power ).
Create your own fuse block distribution straight off the battery, Keep the lighting circuits seperate from the vehicle electrical system. Use relays to tap and trigger the high beams. I did a set of long rangs hood lights and a set of rear back up's that really help the reverse cam. Never had a flicker nor ever used diodes or capacitors. Have been working fine for three years.
I did not put a capacitor in, I get no relay craziness, no high flickering, no codes, nothing wrong that I can tell. Just my 2 cents... Not saying it's right, just saying it works and I have seen ZERO problems.
If you/or anyone else has wiring questions, let me know. Power/Ground for my relay go straight back to the battery.
So when I flip my highs and black magics flip on at the same time. Tons of light. If I ever want just highs and no driving lights with them, I flip my switch, and then its just highs.
