Really need some help from the audio gods
Old Dec 11, 2010 | 08:58 AM
raginbull's Avatar
Default Really need some help from the audio gods
Ok so lets begin. I have a '10 JKU non infinity. Stock head unit. I installed DB651s in the soundbar and trying to figure out the wiring into the crossover for the dash DB6501s components. Someone please chime in, I have my dash pulled apart and ready to install.
I am replacing all the speakers and tweeters. I have already mounted the Polk tweets on the factory pods and speakers in the factory boxes, just need to wire my system to the crossovers.
Thank You in advance!
Old Dec 11, 2010 | 09:02 AM
betjeep09's Avatar
Thumbs up
Wow, man you already got me beat with the dash apart and how did you get the tweeters in there?
Old Dec 11, 2010 | 09:05 AM
raginbull's Avatar
i will post pics and show how once i can get it wired....
Old Dec 11, 2010 | 09:24 AM
raginbull's Avatar
BUMP BUMP! someone, anyone, BUELLER!
Old Dec 11, 2010 | 10:06 AM
CTNEDGE's Avatar
My wires ran from amp to crossover then to component and tweeter. Was marked on crossover which was tweeter.
Old Dec 11, 2010 | 10:34 AM
raginbull's Avatar
My crossover is marked as well but i dont have an amp.
Old Dec 11, 2010 | 11:29 AM
rutdigger's Avatar
Are you using factory stuff or are you adding aftermarket? Is the crossover aftermarket? If so what kind? We need a little more info..
Old Dec 11, 2010 | 12:48 PM
raginbull's Avatar
I am installing the Polk Audio DB6501 component kit with Polk Audio crossover.
Old Dec 11, 2010 | 01:33 PM
rutdigger's Avatar
Ok..assuming you are using the crossover that came with the system you have three places you can hook up wires, Input, Woofer, and Tweeter. Woofer and Tweeter are self explainitory, you run speaker wire from the crossover to each of those components.
The input wire is the wire either from your amp I.E (left and right) or the wire from your headunit. So, for example if you want to put a cross over on your tweeters, put the crossover after the wires running from your front dash speaker to the tweeter. The input on the crossover will come from the wire off the front speaker then run the wire from the crossover labled tweeter..to your tweeter...clear as mud?
Old Dec 11, 2010 | 01:53 PM
raginbull's Avatar
And here is where I am at a stump. Where in Buddha's name is the damn wire for head unit and what do I with incoming wires of the factory for the speakers and tweeters
