Rear windows not rolling down
For some reason on my jku my rear windows won't roll down yet the power locks work fine. The rear controls for the windows don't do anything either. Help me please!
Child safety look out engaged?
I don't have power windows so not sure where it is but should be in your manual. |
I had this problem in my 07. The harness was loose on the rear switches. You have to remove the center console to get to the connection so it's a pain but not a difficult fix.
Originally Posted by austinemiller
(Post 4071895)
this is how I fix my windows when they stop working. turn the key to the on position and at the same time push the window button down and pound on the inside door panel down low with your fist a few times and a lot of times it starts working again.. sometimes the motor just has to move a little and it will start working again. it has worked for me a bunch of times before. hope it works for you.:thumbsup: |
1 Attachment(s)
My rear windows won't roll down, either. No idea why.
Sorry, I had to...check the wiring harness at the door. That's the only reasonable possibility I can think of for both sets of switches not working. |
