Reboot Mygig
Old Sep 4, 2007 | 04:35 AM
CyBrChLd's Avatar
Angry Reboot Mygig
Anyone know how to reboot Mygigstereo? The SAT got stuck over the weekend on an easy listening station and if I have to listen to one more Kenny G song I’m going to drive off the nearest Cliff.
Old Sep 4, 2007 | 07:59 AM
rock342's Avatar
Mine did this - except it was stuck on Country. Lesson learned, don't change the channel!!!
Seriously, mine reset after being switched off for about 4 hours. If all else fails you can always pull the negative terminal off the battery for a while.
Old Sep 4, 2007 | 04:17 PM
CyBrChLd's Avatar
Talking
Thanks that worked , I removed the negative terminal and let it sit for 1hr or so and now it works.
Old Sep 4, 2007 | 06:27 PM
Nelly's Avatar
Is this a common problem? My MyGIG freezes and reboots on its own about 60% of the time when first starting the Jeep. Sometimes it freezes and reboots 2-3 times in a row before I can even adjust the volume on the thing! It is getting really frustrating and it is not easy for me to get to my dealership. :sad:
Old Sep 5, 2007 | 02:24 AM
CyBrChLd's Avatar
mine has only rebooted on me one time but a couple of occasions when i start up the jeep i just get a black screen and i'll have to turn off the jeep and back on.
i'm hoping when the new software update comes out it will fix these issues.
Old Mar 19, 2008 | 06:50 PM
moemar's Avatar
I've been having that problem alot to with the rebooting. DId you find a fix for it?
Old Apr 9, 2008 | 09:58 AM
cmcginnes's Avatar
Mine is doing this (blank screen, no sound -- apparently no function at all) all the time now ... anyone else having this problem? Anyone gotten a fix?
Old Apr 9, 2008 | 11:01 AM
hscrugby's Avatar
Which version of the software are you guys running?
It shouldn't be freezing or rebooting on you.
Download the 9.713 version, install it and see if that helps.
If not, you have something hardware wise wrong, and you should either hit the dealer, or email harmon directly and ask for advice.
Good luck.
