Reccomendations for back up camera and rock cameras for use with LockPick
Looking to get a back up camera and two rock cameras, one for each diff. Any suggestions on these cameras? brands, features to look for, mounting tips? Thanks in advance
I've never heard of anyone doing that but it would be sick! I would definitely recommend getting the widest angle cameras you can. And then see if you can see both left and right tires with one cam. If not, I would put both cams upfront looking at each tire. That way you can have a perfect view of your front end and then you just imagine the rear following that same path.
I would recommend the small cameras that are sold by the Lockpick guys. I have the liscense plate camera, and it's ok. My buddy mounted the smaller camera and I liked how you had more mounting options. The smaller camera lacks lighting or night vision, but that's the only limitation I could see. I'd recommend some rock lights if you plan on crawling at night. Hope this helps.
Cheers!
Cheers!
Thanks for the input guys. I got the idea from a guy who bought an old skid plate of mine. The lock pick has a jack for a reverse camera and tehn two other cameras, so I figure put one to see obstacles approaching the front diff, then another to see what is approaching the rear diff. Don't know how much I will use them, but why not if I ahve the capability? I will make a thread once I ahve everything hooked up.
