Remote Starter Kit advice...
Old 03-20-2018, 04:46 AM
Benzina Bear's Avatar
Cool Remote Starter Kit advice...
Being from San Diego I'm not accustomed to the cold any longer (although I grew up in Ohio). I'm now working in Romania where winters are freezing and summers are hot hot hot. So I decided to install a remote starter in order to have the heat or ac running before I get in my ride.
I bought the Complete Add-On Remote Start Kit for 07\18 Wrangler - Plug and Play.
Complete Add-On Remote Start Kit For 2007-2018 Jeep Wrangler - Plug and Play - Uses OEM Remotes - Firmware Preloaded
This kit works with your Jeep key fob, but not well. I'm sometimes pressing my door locks 3 times by mistake and starting my jeep when I don't want to.
Using your fob you have to be within approx 10-15 feet of your Jeep, so that's not enough time to cool or heat your Jeep during hot or cold months.
CRIMESTOPPER REVO11 RF KIT AM 1 BUTTON, REMO
I had to buy a second kit (above), an RF kit, and I can now start my Jeep after leaving my office and have snow melting off my windshield or have the AC running in the summer.
Here's the advice part.
Tip 1: If you're interested in a remote starter kit get the all in one kit below and only program the one button remote to the starter.
Complete 1-Button Remote Start for 2007-2018 JEEP WRANGLER - Plug and Play for Easy Install
Tip 2: Either way you decide to go, once you program a key fob or one button remote it's twin is ready to go! So you only have to go through programming once.
Tip 3: On the 2017 JKU it is impossible to remove the shroud around the steering column without removing the air bag and steering wheel because Jeep added a lip to the shroud which tucks into the steering wheel. Have a professional help you!
Now I'm happy as a Lark!
Quick Reply: Remote Starter Kit advice...
