Rev App for Iphone
Got my Kiwi wifi for the obdII port. The app seems like a cool toy with some handy info reporting to it.
Here are some pics:
some screen shots:
Buttons in green are reported by the Jk's ECU:
some displayed:
Messed up work schedule this weekend, so no real chance to drive around with it yet.
Here are some pics:
some screen shots:
some displayed:
The Kiwi transmitter is a bit pricey at $149.00, I only went for it because I had a gift card to burn.
The Aeroforce Gauge is also cool with almost unlimited pod mounting options, but not cheap either.
There are a handfull of other programs that can use the wifi dongle including a couple for the PC.
I think the app will be cool when I breakdown and get a hypertech programmer, might give some insight into engine load and other stuff. It would be a cool tool to see if a CAI really changes the air intake temp.
Mostly a gadet to play with and look cool mounted on the dash.
Nope no tranny temp. Not sure about the other iphone app DashCommand
Does the ECU report it? Is there a sensor in place I have seen a few guys on here installing temp probes. Something out of my league requiring welding.
So far the only complaint about the app is that it loses contact with the dongle. I think this is a iphone problem, if another strong wifi signal appears it seems to want to leave the Kiwi, sometimes it will return itself, but a few times I have had to leave the app and go to setting to reselect it.
Damm I need the tranny temp so I can start my experiments with tranny cooling with out adding another cooler. I think the cooler the jeep comes with is getting no air flow so I'm going to make an air scoop and/or add a fan. The Aeroforce intercepter gauge will read the tranny temp from the ODB2 port with out installing a sensor but it's a little too much for me to buy so I can play.
I e-mailed the dash commander tech and they said it doesn't record the tranny temp either
thanks
thanks
Pretty cool app. though. I guess next we will have to figure out were we are going to mount the I-Pad to the front dash
