Reverse signal wire in front driver's side??
Old Jul 1, 2022 | 12:01 PM
peachferrari's Avatar
Default Reverse signal wire in front driver's side??
Going to be installing a backup camera soon and had a question: I want to be able to use it while not in reverse so I'll probably use a switched power source for the camera itself, but I also want it to switch automatically when I go into reverse so I need a reverse signal wire for that. I'm reading about one in the passenger side footwell up by the firewall--is there one somewhere on the driver's side as well?
If not I can run a second wire all the way up the driver's side along with the video cable, just would be easier/less wire if there's something up front where I'll already be into the front driver's side panels to hide the video cable.
Old Jul 1, 2022 | 08:02 PM
Sandau's Avatar
5 Year Member
Yes, there is one in the wiring harness along the drivers side. It should be white with a gray stripe.
Old Jul 2, 2022 | 06:55 AM
Cool I'll have to look for that. Just waiting on my new head unit to arrive so I can see how it's all wired. Hopefully it has everything labeled well
Old Jul 2, 2022 | 05:05 PM
Moodyalaskan's Avatar
If you have a 7-way trailer receptacle you can tap into the reverse wire behind the left taillight where the 7-way plugs into the harness and not tap into the can-bus system as the Jeep doesn't read the trailer wiring.
Old Jul 3, 2022 | 01:17 AM
Sandau's Avatar
5 Year Member
Originally Posted by moodyalaskan
if you have a 7-way trailer receptacle you can tap into the reverse wire behind the left taillight where the 7-way plugs into the harness and not tap into the can-bus system as the jeep doesn't read the trailer wiring.
Old Jul 4, 2022 | 05:47 PM
You lost me--why would it matter if I tap into the can bus sytem? And also I know there's a reverse wire in the taillight for the reverse lamp, I was hoping not to run a wire from there all the way to the front.
Old Jul 4, 2022 | 06:20 PM
Sandau's Avatar
5 Year Member
You don’t have to. You can tap in either under the dash on the passenger side or under the drivers seat.
