Are Rugged Ridge switch dimensions the same as the Daystar?
Old Feb 11, 2013 | 04:48 AM
rickc309's Avatar
Default Are Rugged Ridge switch dimensions the same as the Daystar?
I have a Daystar lower dash panel in my 2012, I like the looks of some after market switches with writing on them such as off road lights and such. The company uses Rugged Ridge switches. I was wondering if they would fit into my existing cutouts on my Daystar panel.
Old Feb 11, 2013 | 06:05 AM
JK-Ford's Avatar
Most switch cut-outs are standardised for the hole itself. But the space above and below the hole isn't. The only way to be 100% sure if a switch will fit your application is to compare the cut sheets. You should be able to find them at the manufacturers web site.
