Security switch!!!!
Old Sep 8, 2009 | 10:53 AM
JEEPSHANE's Avatar
Default Security switch!!!!
want to install a security switch from my steering column, was wondering if anyone has done this??
if so what wires should i tap into??
(base model x, so no security worries)
Old Sep 9, 2009 | 08:31 PM
hvilla's Avatar
I'm interested in this as well... anyone out there with something?
Old Sep 9, 2009 | 08:39 PM
RedneckJeep's Avatar
You could wire a keyed master disconnect switch somewhere under the hood. Maybe to the large wire going to the starter.
http://www.summitracing.com/parts/HLA-002843011/
Old Mar 15, 2010 | 09:11 AM
IN the BLACK's Avatar
Default Kiil switch
Am working on this now. Mounted switch in a KILLER location, run the wires, just need a color code on the ignition wire. WOW $ 300 for a friggin service manual !! Not gona do it. Anybody have one willing to share the color code for this wire? It would save me a bundle of time. Thanks.....
Old Mar 15, 2010 | 09:22 AM
brent_f70's Avatar
I bought the CD version off Ebay $25 but well worth it!!!.....I would look it up for you but I am in Afghanistan and the CD is in my computer room back home
Old Mar 15, 2010 | 10:04 AM
TheonlyREDhead 2008 JK's Avatar
I would like a kill switch too!
Red
Old Mar 15, 2010 | 10:14 AM
js324's Avatar
Id split that ignition wire in half, right there on the 5 pin harness I think its pink/white, seems pointless tho, if the guy is smart enough to bypass the cars immobilizer (chip in key) without taking off any plastic pieces to expose your "security system". Im sure hes smart enough to figure out a simple switch... Our jeeps may seem cheap, but these things are far from a honda civic, accord, or acura integra when it comes to ignition systems...they had the simple n/o n/c design, where ours basically uses a data signal to control when the car turns on or off.
You can get the screwdriver in there, twist and make the car turn on, but without the key the engine wont start...
Old Mar 15, 2010 | 10:22 AM
js324's Avatar
srry for the double post,
If you look up a timed relay, it uses a capacitor and resistors to make a switch with a timer, found HERE then if you were ever to get carjacked, activate that switch and 30 seconds later the car dies thus you can get to a safe place then making the car jacker get out of the car, start running, get tased, and then we laugh..
Old Mar 16, 2010 | 04:18 AM
ripmover's Avatar
I want to do this. Cam someone post more specific info on the how/to?
Old Mar 24, 2010 | 05:41 PM
Bump Bump!
