Severe Electrical Issues
I have a 2014 jk and a few months ago it developed electrical issues i havent been able to figure out. It has 9 codes
P2504 Charging system output voltage hi P0573 Brake switch 1 hi U1417 Implausible left wheel distance signal received U1418 Implausible right wheel distance signal received U1408 Implausible brake signal received C107C Brake pedal switch 1/2 stuck C1000 Brake pedal switch 1 circuit performance C2103 System voltage high C2101 Battery voltage high The problems first started with just surging voltage while driving, i tested the alternator and it tested fine. Battery is still new. Any ideas what could be wrong? Its progressively gotten worse and I cant drive it anymore without the entire electrical system surging. Any help would be greatly appreciated |
Off the bat Id think you have an issue in your wiring harness or one of your modules somewhere. Im not super familiar with the electrical system so I cant help specifically. I would check out any exposed wire harness for damage. It could be a common ground wire for the harness that is broken or another wire chaffing on something causing a short.
Aside from that, even if it were me I wouldnt dive too much into it. Id just let a dealer or another reputable shop handle it. Theyll have high dollar computers there can narrow things down a bit more. |
See if the alternator is ok!! Internal regulator may be going out.
I had similar problems with weird $hit going on when my battery went south
Any idea how to fix? I am having the same problem.
Originally Posted by Ccnuckols
(Post 4416702)
U0141
[QUOTE=elvira_jk;4377492]2014 model bir JK'm var ve birkaç ay önce çözemediğim elektrik sorunları yaşamaya başladım. 9 arıza kodu veriyor:
P2504 Şarj sistemi çıkış voltajı yüksek, P0573 Fren anahtarı 1 yüksek, U1417 Mantıksız sol tekerlek mesafe sinyali alındı, U1418 Mantıksız sağ tekerlek mesafe sinyali alındı, U1408 Mantıksız fren sinyali alındı, C107C Fren pedalı anahtarı 1/2 takılı, C1000 Fren pedalı anahtarı 1 devre performansı, C2103 Sistem voltajı yüksek, C2101 Akü voltajı yüksek. Sorunlar ilk olarak sürüş sırasında voltaj dalgalanmalarıyla başladı, alternatörü test ettim ve sorunsuz çalışıyor. Akü hala yeni. Ne yanlış olabilir diye bir fikriniz var mı? Giderek kötüleşti ve artık tüm elektrik sistemi dalgalanmadan aracı kullanamıyorum. Herhangi bir yardım çok makbule geçecektir.[/QUOTE ]Hello, I'm experiencing a problem with my 2010 Jeep JK 2.8 related to the U0141 fault code. The Full Power Integrated Circuit (FPC) error message indicates a problem with the engine or transmission. |
| All times are GMT -8. The time now is 06:48 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
