Speakers ?
Just cut the wires on the 16 pin plug on the factory amp that go to the speakers under the dash and soundbar and wire in that mini amp. That's what I did and I have no issues. You are essentially just bypassing the factory amp to the speakers. Leave the factory amp where it is and install the mini amp elsewhere. Mine is under the steering wheel zip tied to the bracket thats held on by 2 10 mm bolts
I'm not worried about a "turn on" signal, that can be grabbed from anywhere with the proper ignition position, that's not what I was asking. I mean the sound, the signal for the amp...that is coming from your aftermarket headunit using the pre-outs at the back (rca connection) as the stock unit doesn't produce anything usable with the Infinity system due to the data signal that get's tossed to the amp.
Ah okay, you will need a line out converter if your using the stock radio To get pre amp outputs. Here you go...
https://itstillruns.com/connect-stereo-line-out-converter-5076523.html
https://itstillruns.com/connect-ster...r-5076523.html
NorseLife - if you're up for some more reading here is a great thread on the process to properly upgrade the factory system. I have no desire to dive in that far because my radio is just the infinity setup with no other additions (bluetooth/nav/mygig), but it's a wealth of knowledge on the subject.
https://www.jk-forum.com/forums/jk-e...em-h-u-226953/
I can verify after finishing my install today the speakers run at ~2ohms and the sub runs each voice coil at ~2ohms (meaning it's either a 4ohm or 1ohm load depending on how you wire it)
All in all replacing the infinity amp with my Alpine MRPF-450 and the HU with the Pioneer I chose made a HUGE difference even with using the factory speakers/sub. It sounds much better and at this point I can replace components as I have cash available vs all at once.
