Spod arb problem
You need to fit an air guage to the tank to see if the tank is reaching the set-point for the maximum PSI rateing of the high pressure limit. If you can't hear a leak, this will also tell you if you have a leak.
Compressor pump cycleing OFF / ON - Could be caused by a leak. Could be cause by control power ( but this would eventually stop when the tank reached full pressure ).
It could be a leak, but it's probably literally just the last 1 psi in the system so when you hit the switch in the cab to turn on the compressor, it cuts on, takes a second to sense that it's not needing to keep running, and then it cuts off. At least, that's what it does for me, and I don't have a tank, so I kind of doubt for you it's a leak either. I just think when you run the comp with it hooked up to nothing, i.e. it's not pushing air through the system, it has that auto-cutoff. When I air up a 35" tire, it'll run for several minutes just fine.
I eventually found that the pressure escaped back though the ARB itself. Adding a one-way valve solved it.
The ARB should 'read' the pressure after the one-way valve.
Needing a "check valve" would seem to indicate a problem with the pump.
The ARB backwards leak is unnoticeable under normal use (inflating a tire). The leak is tiny, probably no leak at all when it pushes air forward.
When this happened with the first ARB, the importer gave me another one, brand new - which was the same. I had him call ARB in Australia... They said what I said before:
"It's made this way. If the client insists on leaving it on 'ON', give him a one way valve."
It's now my second ARB (sold the first one with the Jeep). This time I took the twin head, portable, in a case that stores everything.
It inflates and operates pneumatic tools "flawlessly" (pun intended
I understand that "check valves" are an integral part of compressors. And are a commomn point of failure in compressors. I can not speak from experience with this type of compressor. But if this is a repetitive problem with any type of compressor. And it is not manufactured to be a serviceable part. Then I would be looking for another type / brand of compressor. I expect a compressor to hold air. If it doesn't, then it's just about as worthless as a party balloon with a hole in it.
