sPod switch panel and roll cage
Old May 4, 2014 | 02:31 AM
Mud Badger's Avatar
Default sPod switch panel and roll cage
Good morning,
Does anyone have pictures of their sPod switch panel mounted anywhere other than the footmans loop? Pictures would be awesome.
Thank you
Old May 5, 2014 | 08:52 PM
joearod524's Avatar
Are you just worried about clearance with the cage? I've got a Rock Hard cage and I've been looking into the sPod. I've seen a number of people that run both the cage and the sPod without any issues. Hope this helps.
Old May 6, 2014 | 05:50 AM
Mud Badger's Avatar
Well thing is I plan on running the cobra 29 with the KC mount and hanging it right there. From pictures I've seen on wayalife it looks like the CB will be right up against the top of the wind shield and there won't be any room for the switches.
I might just have to get it and play around with switch locations. I might also be able to fab up a little bracket and mount it to the cage
Old May 6, 2014 | 06:40 AM
mattfl's Avatar
Originally Posted by Mud Badger
Good morning,
Thank you
Well the sPod panel is specifically designed to go right there, so mounting it anywhere else will probably take some effort since all the mounts on the panel are designed for that location.
Old May 6, 2014 | 07:28 AM
Mud Badger's Avatar
Ya I figured. That's why I was just curious to see if anyone mounted it anywhere else
Old May 6, 2014 | 03:07 PM
tandom44's Avatar
Default different mounting option for the sPod
Another option for mounting the sPod in the engine bay...found this looking for a way to mount my ARB twin compressor.
ARB Air Compressor Mount from Mountain Off-Road (M.O.R.E.)
Old May 6, 2014 | 03:11 PM
Mud Badger's Avatar
Ya but I'm talkin about the actual rocker switches themselves
Old May 6, 2014 | 04:38 PM
tandom44's Avatar
my bad, misunderstood. here is another thread from jkfreaks about mounting switches...the custom one near the bottom is well done.
lets see your switch and gauge setups
