Steering wheel dance and Hypertech
Old Feb 15, 2011 | 10:39 AM
gundybears's Avatar
Default Steering wheel dance and Hypertech
I have a 2007 2 door, and recently had a TSB reflash, which also updated the ECU to be able to disable ESP with the steering wheel dance. I have been completely unsuccessful in getting it to work and was wondering if it was due to the fact I have the hypertech programming installed. During the last Corral Canyon get together I was having a horrible time in 4HI. It was cutting the throttle over every rock and hill. I tried the ESP off 5 second method, and I tried my ESP kill switch with no luck. Anyone have any advice I need to spin my tires! Thanks.
Old Feb 15, 2011 | 08:22 PM
gundybears's Avatar
Bump. Anybody?
Old Feb 15, 2011 | 08:32 PM
mattgt5's Avatar
I did the steering wheel procedure lsited in the manual on my 08 and it worked. Actually ahd a hard time getting it back before I traded it in. You could set the HypTech back to stock and then try it.
Old Feb 15, 2011 | 08:58 PM
gundybears's Avatar
Exactly what I thought, and the dash lights come on as usual, so I don't get it.
I'll try putting the tuning back to stock and try the factory ESP shutoff, but I doubt it will solve it if the kill switch doesn't work.
Old Feb 16, 2011 | 03:23 AM
zking1776's Avatar
The ESP button on the center console only partially turns off the ESP. You have to do the steering wheel dance. I found http://www.jpmagazine.com/techarticl...tem/index.html that link to be the most helpful for me. I tried using a different one but found that one to be more specific. I didn't realize once you turned the wheel 180 degrees it couldn't move, at all, for the seven seconds. A lot of people can attest it takes a few tries to get it. Good luck.
Old Feb 16, 2011 | 05:55 AM
gundybears's Avatar
Interesting, that article claims I shouldn't have a problem if I use the 5 second ESP hold. So it has to be something else wrong, if the kill switch and factory 5 second button trick aren't working. I wonder if the dealer would check it out for free, since it started happening after the last TSB reflash.
