Stock amp question
Just bought a 2007 JKU Saturday, just got a build sheet today. I haven't been able to find an amp, reading posts here it should be the steering column correct? I have a RES head unit, 6 speakers, but no amp specified on build sheet. I am guessing it WOULD be listed separately correct? So I guess I have no amp. Do I still need to use this $135 CHTO-013BB harness adapter if no STOCK amp is present? What if I go after market amp, do I need to use the CHTO-013BB harness?
Thanks,
Tom
Thanks,
Tom
Anyone have a pic of where the stock amp is located. Every thing I read says behind the panel by the steering wheel. I hate stopping mid job, running for parts, I want everything here when I start. Also, if I DONT have an amp, I am assuming when I put an amp in, I will retain the "non amp" harness. If I choose non infinity system it says one harness, my RES radio has the lazy 8, that is what I assume is Infinity, but the harness avail is the with amp harness. I am so confused.
Thanks
Thanks
I dont have a picture, but unless you have a sub... you dont have the stock amp. The "premium" system came with the amp and sub being the only difference in extra components from the base radio.
Guess I use the non infinity harness then?
Thanks,
Tom
