Stock Sub question
I tore out my carpeting and noticed that I have the wire harness for the stock Sub. Anyone ever just plug a stock woofer in and are good to go? To be honest though I dont even know if the wire harness is hooked into my stock stereo (single disk, no Sirus)
Anyone? |
hmmmmm...
i dont think you will have an amp under your steering wheel column but you could always check, it's a silver metal thing with heat fins and small round mesh on some places of it. if you dont have that, then the wire wont be connected to the stereo system. i think anyways:thinking: |
Would a tester even one of the cheap ones with the light bulb in it work?:dontknow2:
Originally Posted by scotlandjk
(Post 1067878)
hmmmmm...
yeh i guess somtimes its cheaper just to make the harness the same in some places
I don't have sub wiring in mine. I do however have navation wiring under the upper dash panel. Apparently some wiring is provided if you don't have the option but not all wiring.
