Stopping the honk didn't work for me
I tried this from the FAQ:
Stop the "HONK" when you lock the doors using the fob.
Press and hold the Lock button on the fob for at least 5 seconds, while still holding the lock button press the Panic button and release both. Test operation.
I tried it in every way I could think of that still sounds like the described method.
anyone have any tips or advice? it's on a 2008 sahara if that matters
Mine (2008 Sahara) didn't work through several tries. Finally, I must have held the panic button a bit too long and it sounded. After that no honk on lock.
I have not messed with it again, but you might try holding the panic for a second after releasing the lock button.
I tried numerous times to disable the honk on lock and unlock w/no luck also, but I also opted to get the alarm on the jeep so I think maybe that has something to do with it. I'm going to head down to the dealer and see about it tonight.
mine didn't work either, then the other day I was reseting the odometer and turn the jeep on an off several times. I have no idea what I did, but it stoped hunking
If you opted for the add-on security system it is turned off a different way. I called the # for the manufacturer (karr security systems in my case) and a minute later I only have to deal with one honk just when it locks. The guys at the dealer didn't know and said there alarm guy wouldn't be there till thursday....
I ran into this too trying to disbale mine. Finnally just had to start from scratch. Get in-- CLOSE THE DOOR.....turn on, then off your ignition to the last click before ignition. Do it about three times: THEN do the sequence...and do a full One missisisiippi, two Missisippi, etc........ that was the only way I could get it to go.
And that was a breeze as compared to turning off the dang seat belt chime!!!!!!!
