switch power help
I am trying to design my switches for the aux lighting (windshield and bumber), winch control, air compressor, and rock lights. I will be using the Carling Tech switches (V1D1GTTB-00000-000 & V8DAA60B-00000-000).
1. I want to tap into the dash light dimmer to power the LEDs in these 4 switches using the orange wire with grey strip from the A/C panel. Will this be too much for the system and cause it to through errors?
2. I will be tapping into the aux power port (cigarette lighter) to power the switches to trip the solenoids. Again will this be too much for the system?
I have done this on other vehicles with no issue, but we all know the JK can be a bit more temperamental with it computer controlled gadgets. I appreciate any input.
Since I have received several views, but no comments I can only think that either I am way off the path or have it correct.
So I have uploaded a wire diagram that I created to hopefully let you understand what I am talking about. Let me know what I have done wrong or if this is going to over power the system.
yes, the led is on a separate circuit in the switch.
The upper led (8) is independent of the control, thus dim-able. The (on) light will receive the full current thus not dim-able. I may switch to a 1 led switch that is independent of the source power, still making it dim-able.
ECHO thanks, I need the sanity check.
