Switched power?
Old Apr 6, 2007 | 08:53 PM
rramsdell's Avatar
Default Switched power?
Where is the bst place to splice in to ignition/switched power? I read here that some are using the power ports, but I read 12 voltz with ignition off.
Old Apr 6, 2007 | 09:02 PM
Bayou Boy's Avatar
The passenger side cig lighter is 12 volt all the time. Only the driver side is switched with ignition.
Old Apr 6, 2007 | 09:10 PM
rramsdell's Avatar
I'll check again, but I swear the meter read 12V ignition off. I put pos. lead on back center post and the negative on the side.
Old Apr 8, 2007 | 12:03 PM
rramsdell's Avatar
Ok thanks, it is switched. I did my volt check at night and the power only turns off when you open the door! doh!
