Switched power for multiple accessories
I'm looking for switched power for an ARB compressor and 2 locker switch set harness under the left side of the dash, and a Trigger Six Shooter Pod under the hood. I'm headed to the Rubicon in two weeks and I'm running out of time and ability. All I need are some wire colors, if any one of you can help me out?
IMO you're better off tapping a fuse in the engine bay than you are splicing wires under the dash. I suspect your '08 fuse panel might be different than my '13 with 3.6L in which I use fuse M6 as a switched source.
