JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Switches for 2011? (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/switches-2011-a-156931/)
fastrat350 Jan 8, 2011 12:09 AM
Originally Posted by Scuba Steve621 (Post 2021084)
I found out that it was blank and that their is only enough room for 3 switches
Effing awesome!!! thanks man, going to try and order one from the dealer and retrofit it into my 08, hoping the harness plug didn't change much. Hope I can score one cheap enough to try the swap.
Scuba Steve621 Jan 9, 2011 06:48 AM
No problem man. Good luck to ya.
IceGym Jan 9, 2011 08:08 AM
Switch panel for 2011
I ordered a daystar lower switch panel for my 2011 rubicon. I ordered it from quadratec, its advertised to fit a 2011, it dosent fit. Oh well its only 19 bucks, no big deal. Was wondering if there could be a way to modify the 2 together. Dont know where else to put switches ??:crazyeyes:
Scuba Steve621 Jan 10, 2011 02:59 PM
Your guess is as good as mine man. I would think there would be a way?? And I didn't think daystar made a 2011 panel.. Yet..?
JK-jeepit Jan 10, 2011 05:58 PM
I also am looking at adding some lights so I will need switches.. there are three places that I was thinking of. next to Lockers and sway bar switch, the switch panel for the hazard, AC plug enable, etc. 3 empty switches on this panel and then those with 2dr below the two window switches is room for two switches.
1st lockers switch area
http://i1116.photobucket.com/albums/...h/IMG_5229.jpg
2nd
panel switch for hazards...etc
http://i1116.photobucket.com/albums/...h/IMG_5225.jpg
3rd for 2dr jeeps, below to 2 window switches...
http://i1116.photobucket.com/albums/...h/IMG_5230.jpg
as for switches... I was hoping I could get switches that would look similar..
:thumbsup:
subscribed
:wave:
wayoflife Feb 16, 2012 03:17 PM
you can always get a off road engineering custom switch panel like this....
http://project-jk.com/gallery2/main...._itemId=269829
yes, this is on an 07 but, if you use a 2011-up daystar panel, you can mount in the same location. of course, being that the switch panel is so thin and small, you can mount it just about anywhere as you can see below.
Other than using a Daystar panel, to the left of the steering wheel just above the speaker would proably be the easiest place to install one of these...
http://project-jk.com/gallery2/main...._itemId=272286
Or, you could install it just under the center console as shown.
http://project-jk.com/gallery2/main...._itemId=272284
Just behind the cup holders might work well too...
http://project-jk.com/gallery2/main...._itemId=272282
I have a Rock Hard Sport Cage and almost installed it here...
http://project-jk.com/gallery2/main...._itemId=272280
Heck, I even thought about installing it under the e-brake lever...
http://project-jk.com/gallery2/main...._itemId=272278
Being so small and light, you could easily install one on the plastic windshield header cover like this too...
http://project-jk.com/gallery2/main...._itemId=272276
I have also seen where someone ordered theirs to be vertical so that they could mount it to the a-pillar. :yup:
offroadengineering.com/product-multiplex-system.html
Bull Mar 3, 2012 11:47 PM
I'm considering more and more to mount switches directly into the A piller. Saw a couple daystar switches mounted sideways. Has to be alot of room back there. I'm thinking about the small round switches if I cut into the A piller, or I'll hack up a daystar mount and mount it above the rear view. New panel is cheep if I mess it up bad.
nicker22 Mar 6, 2012 12:29 PM
I like the A Pillar mount the best. Looking the rugged ridge one. This way if you ever sell, or trade your jeep you can easly remove that put the factory one back a boom good as new. Plus OTRATTW make some nice switches to go in there.
toolow262 Mar 6, 2012 01:04 PM
Wired HDH
I posted this on another thread but it is getting a few days old and no one has responded to it, so I thought I'd give it another try on a fresher topic. Wondering if anyone has used or heard reviews from the wired hdh flat switch panel. It's not the cheapest way to add a switch, especially if you need the addition of relays for larger power draw, but it looks nice and claims to be made well.
http://www.shopwiredhdh.com/servlet/...HES/Categories
Raisinhead Apr 29, 2012 06:46 AM
I'm planning to mount straight to the a pillar
© 2026 MH Sub I, LLC dba Internet Brands
