Are auxiliary switches available for the stock lower switch pod? My Jeep doesn't have heated seats and it would be nice to be able to use those two capped-off spots if I end up adding accessories.
I'm dabbling with setting up switches that are activated by an iPhone using a headless raspberry Pi and wifi. The hardware to put it together is cheap, but the programming piece is gonna take some learning still. If I ever manage to get it breadboarded up, I'll start posting for real. The great part about this would be no physical switches in the car.
Originally Posted by any4xx
(Post 3952533)
5 Attachment(s)
I made my own secondary fuse relay block as well as a molded switch panel.
Originally Posted by darkknight1999
(Post 3952651)
Originally Posted by orangedude71
(Post 3952658)
oooh. Your molded switch panel gave me a good idea. You have a write up on that somewhere?
(Post 3952651)
(Post 3952604)
(Post 3952651)
Originally Posted by groth797
(Post 3954672)
If you figure this out definitely post it on here! That would be awesome and save some much room. I would totally run that if it works!
| All times are GMT -8. The time now is 05:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
