Switches too bright
Old Feb 18, 2013 | 07:11 AM
Rhino's Avatar
Default Switches too bright
I recently bought the daystar switch panel and 4 of the contura style switches. They're brighter than I expected and will likely be a distraction at night. I'm using them the throw a relay so I'm wondering if I can put something between the power source and the switch to dim them and still have enough power to throw the relays. Alternativley, since they are SPST switches can I wire them so that they're only lit when the switch is in the on position?
Old Feb 18, 2013 | 07:27 AM
Geeps's Avatar
Are they Daystar switches or can you post the product ID of the switches?
Old Feb 18, 2013 | 07:31 AM
Rhino's Avatar
I'll start by saying I know this is my fault for trying to be cheap
switches are Seachoice 10961
marinesupplydock.com/Seachoice-Rock-Switch-On-Off-Spst-Ill-Bk-Model-10961-SCH-10961.htm
Old Feb 18, 2013 | 07:41 AM
JK-Ford's Avatar
You shouldn't "buck" the voltage to the switches. You would probably have to reduce it enough to damage the relays before it even made a differance anyway. Just try and paint the LED's. One or two light coats should do the trick.
Old Feb 18, 2013 | 12:04 PM
spore's Avatar
I put a piece of electrical tape over the offending switches and cut with a razor blade so it just fits over the light.
Old Feb 18, 2013 | 12:08 PM
Rhino's Avatar
I do want some light ideally. Just not that much. For reference this is with the dash dimmer all the way up.
Old Feb 18, 2013 | 12:10 PM
spore's Avatar
Attachment 423855
You could try just putting the tape on half of it and adjust with more or less as needed.
Old Feb 18, 2013 | 06:53 PM
jeepnutt's Avatar
A small piece of window tint over the len on the switch might help.
Old Feb 18, 2013 | 07:05 PM
big c's Avatar
Window tint may be hard to cut and line up right . Could use plastic lens tint that people use to tint their lights
Old Feb 18, 2013 | 07:47 PM
Geeps's Avatar
Are these a three terminal switches and are the switches on all the time?
