Third brake light with Trek top.
2 Attachment(s)
I removed my tire carrier so was without a third light like several people. I'm not sure how big a deal it is since I ran that way for a few weeks with no problem but added one anyway.
This will not work well if you still have a factory top but for the Trek top it works great! Autozone sells an led running board light that comes in red or amber for @ $9. These are the same lights used in bushwacker flat fenders if anyone has seen them. Simple install. Mount directly to the rear roll bar center section behind the rear dome light in a JKU. (Not sure about a 2 door.) Wire directly to the factory wiring. Done. Attachment 429069 Attachment 429070 |
It is illegal to run without it. But who knows if the PoPo would give you a citation for it. Maybe could use it as an excuse to pull you over and check you out.
Originally Posted by JK-Ford
(Post 3456865)
As a LEO I can say I have better things to do than stop someone for a 3rd brake light, as long as the other 2 work. Unless I need it for probable cause to start looking for something bigger.
Unfortunatly, cant say the same for ALL my bretheren. Some are just too anal to let that slide. What did you use to relocate your license plate? I'm looking to do something similar to mine. |
(Post 3456865)
Originally Posted by King_
(Post 3457797)
I have been running without one since Aug 2011 no problems here
The CHMSL (center hi mounted stop light ) actually does help prevent you from getting rear ended as its in the following drivers center vision. If you make a plug-in harness connector ,and stick an LED on with velcro, that's better than nothing.
Originally Posted by Maniak
(Post 3457794)
Have not had one for years , just some people are anal or they just can't see the other two lights , so let me ask how do you not rear end a big truck that does not need the third brake light
http://i257.photobucket.com/albums/h...ps235ecb07.jpg |
Ive been looking for a fix for this myself as i just did the same thing. Great! Thanks:thumbsup:
| All times are GMT -8. The time now is 11:46 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
