Tire pressure monitor system
I have a 2013 Jeep Wrangler Sahara. I just had 20" Fuel wheels and 35" NittonTrail terrains put on. The company that did the package installed new tps on the wheels. The problem I am having is the tps light stays on and they are not reading at all. The person indent with said that they should work after a few hundred miles if not you have to go to the dealer and have them reset it. Can anyone help me out???
Yeah they always get into your pockets. I appreciate the response back but I wasn't sure if you meant the dealer has to reset the tpms or it will just have to reset by itself after a few hundred miles?
Checking with the dealer is a good idea, but the sensors should work within a few miles according to the Jeep owner's manual.
If they won't work, see if you can get your original sensors back. There's nothing wrong with them and you know they work with your Jeep.
No they will turn off right away, make sure the new tires have 40psi in them run for 5 miles then you can back them down to 37psi after the light goes out
I have swapped tires/wheels on my 12 over 8 times never need to go a few hundred miles
The older TPS units only had one model which were the same on all 5 tires.
New TPS units are 5 different models and they are suppose to reset and calibrate themselves but not that many miles to do it. The new units tells the computer which exact tire is low and displays that in the Instrument Cluster.
Demand your money back because I have a 2005 Truck that has never needed replacement or ever offered because the reinstallment kit is well know by the tire world.
It's possible the Installer didn't put the correct ones on. Yes the old can be used over and over, they have kits of the gaskets/seals need to be replaced but the TPS's are reused.
hi, thinking about buying a wheel and tire package from a local shop and they said they would swap out the existing ones on my wheels now. i asked him about the swap and he said he just takes them off and puts them on the new wheel. didnt mention anything about rebuild kit. is he wrong? he said he has done this thousands of times and has never heard of any issues.
Check this out on another jeep Forum, guy asking if tire guy is ripping him off by saying he needs to replace the Gaskets...lol
Replacing TPS gasket?? Or am I being taken for a ride?
[HR][/HR] I'm shopping for replacement tires and after finding a shop in the area with a RoadForce machine he strongly recommended replacing the rubber gaskets on the TPS to avoid leaks. Is this a standard thing to do when mounting new tires? Is he trying to get more money out of me without cause? I approached him with purchasing the tires online and not sure if he's trying to get more money out of me.
Only 24K on the current TPS and entire rig.
