Trucklite issue
Hi guys,
I have installed trucklite with anti flicker adapter for around two years, Recently , I found the right light turned off totally when I pass some road crack, and it lighten again when I pass another crack. The light could work, I'm wondering if the adapter is broken? |
Originally Posted by l0d
(Post 4148099)
Hi guys, I have installed trucklite with anti flicker adapter for around two years, Recently , I found the right light turned off totally when I pass some road crack, and it lighten again when I pass another crack. The light could work, I'm wondering if the adapter is broken?
I've been battling a similar issue as well with my passenger side headlight. It will start to dim and flicker at random time while driving, or parked.
So far I've swapped the anti-flicker harnesses from left to right, gone over the connections numerous time, added dielectric grease to all the connections, and even replaced headlight with a new one from Truckle, and I'm still getting random dimming and flicker on the passenger side. I guess I'll start looking at the OEM wiring next before I trash these things and try OEM or the JW Speakers. It sucks b/c I really like these light! |
Originally Posted by Jeek.OlllllllO
(Post 4148118)
sounds like a connection issue have you looked at the connectors see if any of them made it was to become loose
Originally Posted by ddhowel
(Post 4148149)
I've been battling a similar issue as well with my passenger side headlight. It will start to dim and flicker at random time while driving, or parked. So far I've swapped the anti-flicker harnesses from left to right, gone over the connections numerous time, added dielectric grease to all the connections, and even replaced headlight with a new one from Truckle, and I'm still getting random dimming and flicker on the passenger side. I guess I'll start looking at the OEM wiring next before I trash these things and try OEM or the JW Speakers. It sucks b/c I really like these light!
Happened to me a month after having them. Trucklite told me to zip tie the harness's together tight and put dielectric grease. I did and it was good for about a year and a half. Went off once last week but I poked the anti flicker harness and it came back on
Same here. I was having the dim and flicker on my passenger side light only, this past week. Called truck lite and they told me to zip tie all the connectors and also the antiflicker to something as its heavy. It's Been couple days, and So far so good. Hope that fixed it for good.
(Post 4148149)
Originally Posted by sitting duk
(Post 4148514)
Originally Posted by nickjk33
(Post 4148498)
