turn signals
Not sure if this is in the right place, but is there anyway to tighten the turn signal lever. When using my turn signals they work fine, just when turning back straight the lever goes the opposite way slightly, causing my turn signal to blink the opposite way for the 3 or 4 blink cycle (if that makes sense), haha. Just gets annoying. My jeep is a 2007 JKU sahara.
Mine does the same thing, 2007 JKU X.
Assuming it is the same lever that is in my 13' I would guess there is no way to tighten it, it goes into a sealed electronic unit. However, the whole thing is super easy to replace. There are two torque head screws to remove the steering column cover, two regular screws on the lever unit itself, and then it slides loose, unplug two very small electrical plugs, and you have it out. I picked up a replacement at the dealer for I think $91.00. Reverse the process to put the new one in, and good to go. The whole thing can be swapped out in about 15 - 30 minutes. Super easy.
$91.00 is a bit steep, but calling around to different dealers might get you a better deal on it.
Hope this helps.
Happy Jeeping!
Hope this helps.
Happy Jeeping!
