JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   uConnect Problems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/uconnect-problems-304672/)
dtflick May 31, 2014 06:15 AM
uConnect Problems
I've been reading and searching this issue for weeks now, all to no avail. I hoping someone can help me with this issue.
I have an '07 JKUX the has an RES radio with the uConnect buttons (single CD, MP3, Sirius). I have added uConnect and a USB cable. When I connect my phone to the USB port my phone will charge, but when I hit the AUX button on the radio it says "NO AUXILIARY AVAILABLE". I can use all the phone features through the radio, can connect via Bluetooth, make and receive calls, etc, but cannot get my music to play through the USB port or stream through Bluetooth. I tried contacting Chrysler but they just tell me that it is a compatibility issue, which I call BS on because my phone works exactly the way I expect it to in my wife's Patriot.
I've done everything that I've found online to try and solve this problem (making sure Bluetooth is on and connected to uConnect, switching the output to dock connector on airplay, etc.) but nothing is working. Chrysler told me to just use an Aux cable and connect to the front of the device, which 1) seems counter productive since there is already a USB port in the console, and 2) when I plug it into the USB port to at least charge it while playing music, it cuts audio from the headphone jack so you can't play it anyways, making the USB port completely useless. This certainly is not working as designed, and it may be in the settings of the radio or phone somewhere, but I certainly can't find it.
Enzo May 31, 2014 08:22 AM
I have an 08. the usb is for flashing/transfering only. Yes it will charge.It does not make the phone communicate with the radio.To play music , you need to install the 1/8" jack out of the phone to the radio's jack. The phone controls the music. You will not see any controls on the radio. No info on the music, etc.
I have the touch screen navigation/DVD. There is an adapter cable for Iphone. I believe that cable you will be able to control the iphone on the screen. I had an android, and connected that way. now i have an iphone 5s with different cable so i'm not going to get it from mopar/jeep.
dtflick May 31, 2014 10:20 AM
Is it a radio issue? Only newer radios will work? My wife has the exact same equipment in her patriot, only it's an '11 and low speed bus, but hers connects to the phone and plays music just fine over usb
Enzo May 31, 2014 12:58 PM
That is correct in 2011 they changed the interior, and apparently updated the radio's.
xsdbs Jun 2, 2014 08:03 AM
What is the modules PN & SW version (on the black module's white label)? The radio has some limiting HW that may be causing an issue. Try press and release the voice button and say "main menu, USB". I have seen where the radio AUX button doesn't see the USB signal but will switch with using a VR command.
dtflick Jun 2, 2014 09:51 AM
P/n: 05091960aa
s/w: 63.03.05
xsdbs Jun 3, 2014 06:10 AM
Thanks,
That unit has the most current SW in it. Did you try the voice command and did it help at all?
Originally Posted by dtflick (Post 3923475)
P/n: 05091960aa
s/w: 63.03.05
dtflick Jun 3, 2014 04:15 PM
I tried the voice command but when I said "Bluetooth" it just made the low pitched beep and went to a different source. I've checked my phone several times and it says that it is connected to "uConnect" on the source list, but can't for the life of me get it to play through the radio.
xsdbs Jun 4, 2014 05:55 AM
Maybe I wasn't clear on the command. It didn't include Bluetooth, that's why it went to a different source.
Press and release the voice button and say "main menu, USB". Speak in a normal speed, not too fast or slow. I seem to remember something about the radio's HW doesn't recognize the iPod / IPhone connection so it won't switch but if you use the voice command, then Uconnect will switch the source.
dtflick Jun 4, 2014 01:54 PM
Same issue. I use the command "USB" and it gives a low pitched beep and witches to AM. Say "Bluetooth" and get the same result. Say "Main Menu" and it gives me the option to say either USB or Bluetooth Streaming Audio, but when I say either of those I get the error beep and switches to an alternate source.
© 2026 MH Sub I, LLC dba Internet Brands
