Under Dash Lights
2 Attachment(s)
Hey,
I've been doing a bit of investigation on under dash lights. I have a 2013 that comes with the lights stock but I don't like the colour and cannot change them since they are a sealed LED. I've replaced the rest of the interior lights with LEDs to the 6000k colour and would like to add LED strips under the dash and use the wiring for the existing lights. When I looked under the dash at the harness I noticed that beside each of the lights on either side of the jeep is a box that is labeled "LHD". What is this box and what does it do? The plug going into it has 4 wires I believe. 2 power the light and I'm assuming the other 2 power whatever the box does? Would I be ok the cut the 2 wires that feed the light to supply the LED strips, and leave the other 2 wires to plug into the connector? Attachment 399699 Attachment 399700 Thanks Brent |
Originally Posted by 2013Wrangler
(Post 3342278)
Hey,
I've been doing a bit of investigation on under dash lights. I have a 2013 that comes with the lights stock but I don't like the colour and cannot change them since they are a sealed LED. I've replaced the rest of the interior lights with LEDs to the 6000k colour and would like to add LED strips under the dash and use the wiring for the existing lights. When I looked under the dash at the harness I noticed that beside each of the lights on either side of the jeep is a box that is labeled "LHD". What is this box and what does it do? The plug going into it has 4 wires I believe. 2 power the light and I'm assuming the other 2 power whatever the box does? Would I be ok the cut the 2 wires that feed the light to supply the LED strips, and leave the other 2 wires to plug into the connector? Attachment 399699 Attachment 399700 Thanks Brent Just a suggestion. I used the prewired single LED bulbs on my center stack. Just drill the holes to the correct size so that the bulbs just fit. I just installed three under the ledge that overhangs the A/C controls. A little dab of silicone will hold them in. Then you have excillent indirect lighting that looks custom. :thumbsup: |
Originally Posted by JK-Ford
(Post 3342444)
IDK what that box is. If your sure that you are tapping into lighting circuits, then I guess that it really does'nt matter where you tap in at. There is a thread floating around here somewhere that describes how to tap the wiring behind the A/C controls for this very same purpose. Be very careful around the control wiring though. You don't want to tap into a CanBuss circuit.
(Post 3342456)
Sounds like a good idea. Do you have any pics of this done?
2013 has footwell lights? nice.
I'm about to start a project installing RGB l.e.d. tape with a controller to adjust the color. Probably going to just wire it to a switch, although I've been thinking about using a double throw switch to turn them on manually or wire them to come on when the interior light is on. |
2 Attachment(s)
That's real cool the new JK's come with this lighting. I wired up 12" bright white led strips under the dash in the foot wells. Tapped into Dome light to turn on and off.
Attachment 403419Attachment 403420 |
Yeah I think I'm definitely going to wire them to a double throw switch. On with accessory / Off / On with interior dome lights.
Which 12" lights did you use? |
This helps, but leaves more mystery...
(Post 3342278)
Hey,
I've been doing a bit of investigation on under dash lights. I have a 2013 that comes with the lights stock but I don't like the colour and cannot change them since they are a sealed LED. I've replaced the rest of the interior lights with LEDs to the 6000k colour and would like to add LED strips under the dash and use the wiring for the existing lights. When I looked under the dash at the harness I noticed that beside each of the lights on either side of the jeep is a box that is labeled "LHD". What is this box and what does it do? The plug going into it has 4 wires I believe. 2 power the light and I'm assuming the other 2 power whatever the box does? Would I be ok the cut the 2 wires that feed the light to supply the LED strips, and leave the other 2 wires to plug into the connector? Attachment 399699 Attachment 399700 Thanks Brent https://youtu.be/zB8jxRntEoA |
