Upgrading to factory fogs
I got a front bumper with the factory fog lights in it and can't find any place that sells the wiring harness. Jeep dealer said the only way they sell it is with the lights which runs something like $200.
Anyone added the factory fogs and have some advice of where I can buy the wiring harness? Thanks
I recently did something like this. I bought a rubi front bumper with the fogs. The guy had cut the wires really close to where the connector meets the fog lights. So I had to solder some wires to extend them. I then ran those wires up and followed some of the factory wiring routing. I then removed the front grill to get access to the pass side headlights. I then added a new wire spliced on to the low beam signal. I ran this wire to a relay that I bought at Radio Shack for 6 bucks. Part 275-226 (UPC 040293130206) . The Low beams are my "trigger" to turn on and off the lights. This worked for me. I hooked up the proper terminals to the battery and to the fog lights. It works that when i click the high beams the fogs turn off, as others has mentioned is some kind of law in some states. I put what crappy pictures I had on piccasa. http://picasaweb.google.com/philfronz/FogLights
Overall the install was pretty easy.
PM this guy and see if his extra wiring harness will work
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/delta-fog-light-jk-upgrade-question-43199/
My solution was to pay another JK-Forum member $25.00 for a set of factory pigtails he was parting out of a full wiring harness. When it gets here, all I will have to do is splice the hot side to my eBay harness and ground the other.
Of course, this doesn't help you much, but what I was going to do before this deal came up was to order this kit from my Jeep Dealer who gives me 25% off list:
Fog Light, Installatio*n Kit
Part Number: 82210549
Vehicle Description: 2008 Wrangler
Jumper Harness, Connects production fog lamp wiring to bullet style Mopar Fog Lamps. 18" long. Used when installing Mopar bumpers in place of production fog light equipped bumpers.
List Price $22.55
If this plugs into your fog lights, and I think it might, you could get this done cheaper than the deal I put together. By the way, I saw a wiring kit like the one I got off eBay for $12.50 instock at Autozone. Good Luck.
Folks the pigtails you seek are available at any auto parts store.
The bulb in the factory fogs is a GE 9145, the pigtail you get for $5 at the auto parts store is 9005 plug.
I am making the wiring harness for my upgraded bumper too.
I am putting a relay distribution block between the battery and the fuse box, theres a place just asking to be filled there. Then I'm installing a four switch panel in the interior and running the wires to the relays. I will have three more switched/relayed outputs ready to go as I add more stuff.
