Using OEM Fog Light Switch to turn on afermarket Fog Lights?
I want to install a pair of 100-Watt KC Fog Lights a buddy gave me on my new Mopar Bumper and still be able to use the OEM Fog Light Switch to turn them on!
So I wouldn't have to splice into the wires, I ordered the Mopar Fog-light wiring harness which plugs in to the existing fog light connecter and has bullet connecters at the ends. I Plugged the KC's in and no luck! The Fog lights just fade on/off.
Any Advice?
Thanks,
Any Advice?
Thanks,
If you use the factory switch you will have to use a relay on the switch and draw additional power from the battery or other source. If you run your KC's off the stock power you will start to blow fuses due to the wattage difference.
I'm assuming that If I follow KC's wiring instructions up to the point of connecting the Relay to the On/Off switch, I'll instead connect it to the JK's OEM fog light switch?
There are 2-wires that go from the KC Relay to the KC 's on/off switch... a green wire marked (LOAD) and a white wire marked (SUPPLY). I hoping that if I attach those to the OEM Fog Light Switch it'll work.
But which wires do I tap in to?
True... I noticed the OEM Fog Lights are 42-watts.
Well I decided not to go further with this project as I dont want a whole lot more cabling in the JK and dont want to splice into cables just yet!
F.Y.I. I spoke to a Jeep Service Dept Rep, who informed me that you can put 55-watt fog lights on the JK and no more than that. But he also said "not all 55-watt third party fog lights" work on the JK (???). He recomended Hella FF75 lamps which are the same ones you get if you order the Mopar ones for the JK. Only differance is the Jeep logo in the lens.
