View Poll Results: WHAT CB?
Cobra 75 WX
8
72.73%
Cobra 29
3
27.27%
Other....if so.....what?
0
0%
Voters: 11. You may not vote on this poll
What CB do you recommend? Cobra 75 or Cobra 29?
Old 10-15-2010, 07:01 PM
Matador's Avatar
Default What CB do you recommend? Cobra 75 or Cobra 29?
What CB should i get? I had the Cobra handheld and hooked up a 4' firestick but i didnt like how akward it was. Going to go with a regular installed one.
Should i get the Cobra 75? or should I get a full sized one like a 29?
Thanks,
Matador
Old 10-17-2010, 11:30 AM
Matador's Avatar
bump bump
Old 10-17-2010, 11:41 AM
aristobrat's Avatar
I like the Cobra 75. It performs well enough, and I like that I can super-easily remove it from my Jeep the other 29 days of the month that I'm not using it.
Old 10-17-2010, 09:36 PM
runit3's Avatar
I've got the 29 WXNW (NOT bluetooth edition). It's definitely full size. I had to retrofit my Tuffy overhead w/a step drill to bore out a hole for the coax wire in back, only real issue with size though. The CB itself is AMAZING to use, internal SWR adjustment and cal modes are extremely handy. If you ever knock the antenna mount on a trail or get a funky SWR reading it takes less than a minute to re-tune to spec instead of having to hook up inline adjustment tools. Quick switch to 9/19 and weather channels is also nice, buttons are big enough to operate and memorize w/out looking up while driving.
Both the 75/29 are similar in price, maybe 20 bucks more for the 29. The main issue is how much space you have to work with, and if you want a permanent install (which I did).
Old 10-18-2010, 09:25 PM
fitzb's Avatar
Have cobra 75, although I don't use it that often, I love it !!!!! small and easy
Quick Reply: What CB do you recommend? Cobra 75 or Cobra 29?
