Will higher wattage bulbs work
Old 02-26-2008, 07:14 AM
Areomax's Avatar
Default Will higher wattage bulbs work
I was planning to change my headlights to a higher wattage bulb. Has anyone done this and will it work without problems. Otherwise Ill try the silverstars.
Old 02-26-2008, 09:12 AM
poppakristof's Avatar
I think it will draw more current and that leads to melting of the wiring.
Old 02-28-2008, 08:47 AM
seal20's Avatar
No they won't work.
Hope that helps.
Old 02-28-2008, 08:50 AM
BLKRUBI's Avatar
Almost. They draw more current, but will trip the relays to cut off before melting anything, making them useless.
Old 02-28-2008, 09:15 AM
Sahara's Avatar
try the phillips vision plus bulbs
Old 02-28-2008, 07:56 PM
True, hopefully they do trip.
Old 02-29-2008, 12:12 AM
davidwm71's Avatar
If the headlights are like the foglights they wont work. People have installed 55 watt fogs in place of the 42 watt bulbs and had some strange results.
Old 02-29-2008, 05:18 PM
Wopdego's Avatar
Default They will work
I put in a set of Vision X premium white headlights. They 80/100 Watt xenon lights. The stock lights are a 55/60 Watt so they are quite a bit brighter and very white. They also give the headlights a nice blue colour when they are off. Their website is www.visionxonroad.com you are looking for the H13 light. I think the model number is VX-HH13. They cost me less than $25 for the pair. I have been running them for over a month with no fuse or melting problems.
Old 02-29-2008, 05:29 PM
BigKahuna's Avatar
I have upgraded my factory fog light bulbs (42 watt) with NOKYA 55 watt bulbs about one month ago. No problems here
Old 02-29-2008, 07:04 PM
JK-ing's Avatar
Cool
I also have replaced mine with Vision X bulbs and it made a hugh difference. They are a deal at under $20 a pair.
Quick Reply: Will higher wattage bulbs work
