Windshield Light Bracket install question
Old Dec 25, 2011 | 05:15 PM
Hydroslyder's Avatar
Default Windshield Light Bracket install question
Hey everyone,
I've got the MBRP windshield light brackets and I was wondering if I should put anything between the brackets and the windshield to protect the paint from any wear or scratching from the long term mounting of the brackets. It may not be a big deal but figured it would be easy enough to put in a little prevention now.
Thanks
Old Dec 25, 2011 | 05:20 PM
BStelling's Avatar
I forget what it's called but I used a sort of foam plastic liner kind of like what you use in a drawer to keep things from sliding around. I found it in home depot near the kitchen appliances. After a year, so far so good
antonioso's Avatar
A thin piece of rubber will do the trick. But its gotta be really thin as to not leave a noticeable gap.
Merry Christmas
Old Dec 25, 2011 | 05:57 PM
Durangoman's Avatar
Originally Posted by Hydroslyder
Hey everyone,
Thanks
Bolted up solid, they wont be moving around and scratching. I didnt put any type of gasket with my MBRPs. Besides, and IF they did scratch--- heck its a Jeep. Jeeps are suppose to be used and get scratched up...
shoe1724's Avatar
I used an old bike tube in between the bracket and jeep.
Old Dec 25, 2011 | 06:04 PM
JOSH27's Avatar
Maybe put a couple strips of double sided tape on the bracket with the backing still on?
Old Dec 25, 2011 | 06:31 PM
I obviously wasn't the only one that thought this lol. Bike tube sounds like an excellent idea! I know it's a jeep but if I ever decided to remove the brackets it would aggravate me if there was a bracket shaped rub spot on each lower windshield corner.
Old Dec 25, 2011 | 06:44 PM
OH9JK's Avatar
JK-Forum Ambassador
Electrical tape or a thin layer of silicone will do the trick.
Old Dec 25, 2011 | 06:45 PM
305jk's Avatar
Did the same thing... Got an old intertube from an old bike, cut it and perfect fit... Great way to go and cheap
Old Dec 26, 2011 | 09:49 AM
Ryan0260's Avatar
Guess I got lucky....mine came with a liner
