WONT CRANK need electrical help
So I was installing a new smittybilt bumper with winch. After installation was done we plugged up the remote and tested the winch. The winch worked fine for about 5 minutes then the whole jeep died and wouldn't crank. I tried to crank again but nothing would work, no interior lights no odometer , nothing . Eventually the odometer would come on barely and twitch a lot but still no crank.
A few notes: I also have a 1000 watt sub amp, 1000 watt kc lights already connected to the battery.
Can annyone tell me what may be wrong?
If it was on its way out. Stock battery is not meant for deep discharge. Were you listening to the stereo during the install? Double check your connections on the battery. Meaning are they tight with no corrosion. Sparking could be the clicking. How did you hook up the winch? Did you double check the main ground from your battery? Check your polarity.
Sent from my SPH-L900 using Tapatalk 2
The winch was grounded and worked fine, the jeep just went dead. So then we unhooked the winch and put the battery back like it was before and nothing happened still, alone or trying to jump it .
