Would these work instead of the current fog lights...???
Old Feb 29, 2012 | 07:46 AM
MotiCross's Avatar
Default Would these work instead of the current fog lights...???
h t t p://w w w.ddmtuning.com/Products/LED-Work-Lamp#tabs
They have other ones but i want to maybe change the current fog lights, anyone done it? or have any info as for size and other specs?
Thanks
Old Feb 29, 2012 | 08:05 AM
JK-Ford's Avatar
Thanks
I know that you broke the link on purpose. But I can't find that fixture. But I can say this: If you are replacing a fog light with a work light, you will get poor results.
Old Feb 29, 2012 | 08:12 AM
MotiCross's Avatar
h t t p://www.ddmtuning.com/Products/LED-Work-Lamp
Try this one. i'm looking at the 156mm or 128mm..
Old Feb 29, 2012 | 08:27 AM
JK-Ford's Avatar
OK. I found the fixtures that you are talking about. Still, you shouldn't replace a "Fog" beam pattern with a "Work / Flood" beam pattern. The fog beam pattern has a very sharp cutoff just a few feet above the ground. Fog lights concentrate the lighting on the ground under the fog. Flood lights have a very big circular beam pattern. If you use this beam pattern in foggy weather, you will not be able to see 3 feet in front of you. If you use them in normal weather, you will blind everyone. Not to mention, they would be considered illeagle for street use anyway.
Old Feb 29, 2012 | 10:15 AM
MotiCross's Avatar
Thanks for the info, but yes i was looking to replace it so i can have better offraod lighting and no fog light and not for everyday driving.
Thanks again!
M
Old Feb 29, 2012 | 10:36 AM
JK-Ford's Avatar
Thanks again!
M
Oh! OK, Well I don't know if they will actually fit. But they would probably be OK for what you are looking for. And I don't mean to keep dinging your idea. But a good set of lights mounted on top of the bumper would work best.
Old Feb 29, 2012 | 10:39 AM
MotiCross's Avatar
Oh defintely, I was just looking for a quick / cheap fix for next weekend night run lol
One day it will have a full blown light bar
Thanks though.
