JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Axle alignment off. Is this stuff bent?
Old 10-05-2014, 05:46 PM
CerOf's Avatar
On a side note, seriously consider c gussets. With 34" tires combined with wheeling your rig, they will eventually bend. I run a small 33" and
My driver side was slightly out. Not enough to cause unusual wear or driving characteristics, but enough to confirm they are important to do.
Baertrax over around royal and 35 did mine. Did great work and reasonable.
Sent from some string and a few tin cans.
Old 10-05-2014, 08:16 PM
Sazerac_TX's Avatar
Originally Posted by CerOf
On a side note, seriously consider c gussets. With 34" tires combined with wheeling your rig, they will eventually bend. I run a small 33" and My driver side was slightly out. Not enough to cause unusual wear or driving characteristics, but enough to confirm they are important to do. Baertrax over around royal and 35 did mine. Did great work and reasonable. Sent from some string and a few tin cans.
Funny you should say that! I was planning to drop off with them this week for that very thing. I assume it's worth it on a D33 versus waiting till it breaks and upgrading to D44? ;-). Is a gusseted/sleeved D33 as strong or stronger than a stock D44? From the C's concerns I would assume stronger.
Old 10-05-2014, 08:41 PM
CerOf's Avatar
Should be close to the same strength. Outers on a D30 are the same as my 44. The big strength gain with a 44 is a larger R&P. I think axle shafts are a bit bigger. Seems tubes are the same size...not 100% sure. I am certain outer 'C' is the same.
Old 10-09-2014, 07:40 PM
Sazerac_TX's Avatar
Default Git er dun
Got it done. Gusseted, sleeved and new Synergy ball joints to boot. Let's roll.
And nothing important was bent. Steering linkage perhaps, but Baertrax just recentered steering and said rock on.
Old 10-13-2014, 09:17 PM
sea bass's Avatar
Happened to me once. Ended up being the drag link with a slight bow. Does yours look straight or curved?
Old 10-13-2014, 10:15 PM
Sazerac_TX's Avatar
Slightly curved. Just straightened the wheel and I'm back in business. If it bends much more I will probably investigate new drag link.
Old 10-20-2014, 10:44 PM
JK505's Avatar
I had my axle pushed to the driver side by 1.5" after my lift. Invested in a Teraflex monster track bar and got it centered and fixed a bunch of issues I was having
Quick Reply: Axle alignment off. Is this stuff bent?
