Originally Posted by scouter4life
(Post 855871)
Now that makes a lot of sense. I could see a jeep with the front hooks connected to the red, it would be strong and safe.:thumbsup:
Originally Posted by Pwermker
(Post 853760)
The best knot to use is called a "Bowline". Do a search for knot tying and you can get a detailed description on how to tie it. It is tough to remember how to tie it but it won't bind or slip. I use it to secure trees to vehicles when cutting them down and to tow. The knot will come apart very easily no matter how hard you pull on it.
For two straps together I'd use a water knot, rescue teams use it to tie their straps together http://www.animatedknots.com/waterknot/index.php but I doubt if you'd ever get it apart :dontknow2: and on that note, my vote is for a shackle done w/ a blanket over the straps. |
Originally Posted by Until2004
(Post 854842)
...you are not gonna knot a strap. If you cannot reach it with one strap, and you don't have a dowel/branch to use the dowel method, use of multiple straps is possible by simply running an additional strap through your end loop and attach both it's end loops to the Jeep to be towed, essentially creating a cradle. No knots, no dowels, no shackles. More than one can be added in this fashion just by running the next one through the end loops until you have enough length.
Kinda like this: https://www.jk-forum.com/picture.php...pictureid=4466 |
Originally Posted by 08{GA}RUBICON
(Post 856379)
This seems to be the way to do it and you will have the two straps tied together in a super tight knot after the recovery.
Originally Posted by Mr.RonGilbert
(Post 857613)
we carry shorter straps if need be |
Don, if you need a nice dowel, I have the end of a shovel I use.
When I break another shovel, I will give it to you...I usually break one a month. I might be due to break one just before the next Wolverine meeting, if so I will bring it Dave |
(Post 857613)
I'm with 08 Rubi and Until - use the dowel or cradle method - both are easy to untie and if something fails it is more likely to just fall to the ground than become a high speed projectile. http://i75.photobucket.com/albums/i3...hare/dowel.jpg . |
it is simple to pull apart all you do is pull them back apart the way you put it together
lie 2 straps together going the same direction take strap 1 loop and put it through strap 2 loop at one end at the other end take strap 2 loop and put it through strap 1 loop have someone hold at one end the loop the went through the other loop while you pull on the opposite end loop that went through the loop once you get the ends to meet up just put something in the middle paper plates a branch or something that will not let it cinch up to remove just pull the loops back out |
Originally Posted by dsp
(Post 858402)
(Post 853760)
