Going downhill offroad JK
I drove a jeep a few years back at Jeep 101. One of the things they demoed was going up and over a large hill. On the way down the jeep was controlled and crawled down slowly on its own. I tried this in my 2007 JK X the other day and that wasn't the case. I ended up having to brake all the way down.
I don't know a ton about cars so not too much ridicule if this is a stupid question, but what do you all think would be the difference and what made that other jeep crawl down so controlled. It was a stock jeep. Is there something I can mod on mine to make it crawl down like that?
Yeah, I was. I shifted into 4 wheel low, but then a few days later found out that I had broken this disc that threads the cable on the shifter. I wonder if it didn't go into 4wl and was maybe stuck in 4wh
Yeah, I went to show my buddy who drives an FJ how it goes downhill and it just went like a mad truck downhill. I told him that isn't how it happened on my old jeep and the last one I drove.
I would also think that you want to be in the lowest gear possible. Mine is a standard so i leave it in 1st as well and let the engine compression do the braking. If your's is an auto then I would think that you would want to shift into L1 as well. (Not quite sure what the readings are on the auto)
Most people drive their autos in D continuously. The other gears are available and should be used. In this situation I would definitely use L1 or whatever it is labeled for going downhill.
Are there other times that I would use D3 or L2...yes. Whenever I towed something like a boat at the max weight I would start in a lower gear and shift up while I was driving/cruising.
I have standard trucks and jeeps so I have never offroaded with an auto so no response from me on if you should do it as a default measure.
My initial response is really regarding going downhill. Engine compression works great.
