Hi-Lift or Hi-Lift's FIRST RESPONDER ?
Is the Hi-Lift's First Responder better than the regular Hi-Lift for wheeling ?
From what I read, the advantage for wheeling might be the rotating base -- with wooden blocks to sit on, it might allow better grip in some circumstances.
Comments? – From firefighters who have used it, maybe?
Thanks!
Thanks!
Well, it doesn't spin freely of course.
It can be unlocked, rotated on it's base, then re-locked, before you use it.
The base can sit on longer wooden blocks.
Because it can be rotated, the blocks can be positioned either along the Jeep or perpendicular to it.
You can see it at - .....firstresponder.hi-lift.com
Yeah, expensive.
I think of bolting a plate under the Hi Lift's base – shaped so wooden blocks can be placed under it in two directions, either '–' or 'I'. At the same time, it may have pegs at the 4 corners, which stick in the ground.
My department has one, and I have used it. It has a lot of functions from vehicle stabilization to clamping and different attachment points to use for pulling from different angles. I am going to buy the conversion kit for my hi-lift.
