JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Hi-Lift vs. Farm Jack
Old Apr 11, 2017 | 03:23 PM
Wuebben.2's Avatar
Default Hi-Lift vs. Farm Jack
What's the difference between a hi-lift and a farm jack? I was at TSC the other day saw a farm jack, and it's less than half the price of a hi-lift. It seems that the only advantage the hi-lift has is the minimum jacking height.
Here's a link tho the farm jack
http://www.tractorsupply.com/tsc/pro...n?cm_vc=-10005
Would this be an equivalent less expensive alternative?
Old Apr 11, 2017 | 05:03 PM
MrChuckles's Avatar
Yes. A lot of people use farm jacks. They're pretty much the exact same thing, but you're paying for the hi-lift name. Also, in general, those style of jacks suck, so I'd save my money if I were you.
Old Apr 13, 2017 | 08:38 AM
Wuebben.2's Avatar
Why do they suck? Growing up on a farm, my grandfather used one for almost everything...and from what I've seen they are extremely useful on the trail. What do you suggest I spend my money on? (I'm new to the jeep & off roading community and would love to learn)
Old Apr 13, 2017 | 08:49 AM
catahoula's Avatar
I got a tailgate jack mount for sale if interested. What are you using jack for? Do you have larger tires that the factory one is too short?
Old Apr 13, 2017 | 06:29 PM
TreyJK's Avatar
I use mine every now and then; it's a Hi-Lift brand and I've had no complaints!
If you buy one, please watch a few videos and read the article over on Expedition Portal so you don't accidentally knock your teeth out when it comes crashing down!
Also, there are few places on a stock JK that you can use these jacks. They're almost worthless unless you have steel armor from which to lift.
Old Apr 14, 2017 | 04:21 AM
Hail2Ale's Avatar
i have a 48" hi-lift on my hood and will keep it there. also have a 10K winch and 6k come along. I don't like being stuck.
Old Apr 14, 2017 | 08:19 AM
2MchFun's Avatar
Pretty much the same thing. As someone mentioned above - learn how to use it properly. Improper usage can lead to serious injury to you and/or your Jeep.
Old Apr 15, 2017 | 07:03 AM
jeepmojo's Avatar
Default dangerous maybe but
id rather have one than be stuck and not have one . when your out in the boonies alone . Caution and safety is always recommended for any situation . Mine sits right behind my drivers seat in my 2 door 42 "hi lift jack/ i dont have a winch nor do i want one
Old Apr 23, 2017 | 04:13 PM
WaterRat72's Avatar
I have a farm jack from Harbor Freight. No problems whatsoever. Just take care of it and learn to use (this style) jack properly and it should serve you well for years. No reason to pay for the name IMO.
Old Feb 25, 2019 | 12:45 AM
Sodak's Avatar
Veteran: Marine Corp
I have the 48" high lift.. and there's a very good reason they call them Widow Makers... Now I have found a piece from JEEPNEEDS that helps a lot... and it works..
