JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Jeep is stuck after 4hi help!!!!
Old Nov 2, 2012 | 03:04 PM
Rubitron27's Avatar
Default Jeep is stuck after 4hi help!!!!
I put my jeep in 4hi then disconnected sway bars to check something. I used my hilift on both sides then lowered it down and backed up. My jeep is like lurching and the back end seems to be stuck in the air. My shocks are extended really far also. Please help.
Old Nov 2, 2012 | 03:15 PM
Rubitron27's Avatar
False alarm I think my rear sway bar was stuck a little
Old Nov 2, 2012 | 03:17 PM
BigLow's Avatar
JK Forum Regional Rep
It's hard to tell from the pictures and your description what the issue is exactly. Take a look at your coil spring perches and make sure the coils are seated.
What do you mean by the jeep is "lurching"?
Old Nov 2, 2012 | 03:24 PM
Rubitron27's Avatar
I think it was because I was disconnected when I backed up but when I turned it felt like it caught and then I tried to accelerate and it wouldn't I took out of 4hi and it went away
Old Nov 2, 2012 | 03:29 PM
Zombie Hunter's Avatar
Just getting ready to post that from looking at your last pic.
Those look like OEM rear end links. I'd get proper lenght end links before this happens again, or something else worse.
Old Nov 2, 2012 | 03:33 PM
Rubitron27's Avatar
That is what I think it wrong usually there level like the front because those are extended links from the 4" teraflex kit.
Old Nov 2, 2012 | 03:37 PM
Rubitron27's Avatar
I did not install my lift myself so there is a chance that they are OEM links I will look into that thanks
