Min Tire Pressure
Min Tire Pressure
QUESTION
RUNNING 315/70/R17 ON MY STOCK MOAB RIMS
WHAT IS THE MINIMUM PRESSURE THAT I CAN AIR DOWN TO
SO THAT I DON'T BREAK THE BEAD
Well like the previous post said it's hard to generalize as we don't know what type of tire you have and how strong the side wall is.
Another factor to consider is weight. Do you carry a lot of stuff with you? If the answer is no, than start off with high teens and start dropping it down 1 lb at a time to see how the tire performs and how confortable you are with it.
There is absolutely no point to go down to single digits with the tires you have. If you do, it will be pretty much like running four flats, and your tire will not have footprint pressure.
I'm usually running with a minimum of 500 lbs and I ususally stay in the high teens for the trail. The ride is noticeable smoother, as well it has sufficient foot print pressure for the weights I'm carrying.
THANKS
THE TIRE ARE PRO COMP M/T EXTREMES
JUST OFF THE BAT
FRONT BUMPER AND WINCH ADD 200LBS
REAR W/T RECOVER GEAR TOOLS FOOD ANOTHER 200LBS EASY
THEN ME AND MY NAVIGATOR IE FATHER 400LBS
SO WE ARE LOOKING AT BUMPERS OCCUPANTS GEAR 800LBS
GEE I THINK I NEED A DIET OR BIGGER JEEP
JUST OFF THE BAT
I don't think that anyone would have such a chart. It would pose liability issues. The tire pressure that you ultimately want to run depends on several factors including tire and rim sizes, vehicle weight, and terrain being encountered.
I start at 15 psi for all day trips for all types off wheeling. I have not gone on a trip loaded down with camping gear yet but i will start at 18 psi and check the side wall buldge and go from there.
I have ran in the snow down at 10 psi.
