Newer jeeps Off road
How good are the newer jeeps in water and mud? Do they hold up to regular driving in deep water say a depth of two to three feet? Live I'll central Florida and ride and hunt the swamps a lot. Currently using an old pickup in the woods.
Just dandy.
If you're going that deep in water then I'd suggest the following items (at minimum): 1. 3.5" lift 2. M/T tires 3. Snorkel 4. Winch with recovery gear |
I would keep using the old pick up.
Already planned on lift and tires. How about breathe tubes would they need to be extended?
Originally Posted by TheDirtman
(Post 4285677)
^ I agree with Dirty..... Lift + extended breathers are fine. It's changing the damn axle seals every other month that would get old real fast. You might get lucky and maybe able to extend that out to 2 or 3 months but eventually you'll have to swap them out. Axle seals do not like mud...... . |
One would think the seals would be better in a jeep. Guess I'll just rebuild my old Toyota engine. I know the axle seals in my f250 make noise. The outer dust seals. I don't think there's a superduty that doesn't if it sees a dirt road even. Thanks for y'alls input.
Originally Posted by Fishbones182
(Post 4286047)
You would think! You can put axle tube seals in the front axle, but it's hit or miss. I've never run them but some claim that it only traps the dirt in thus making it easier to penetrate the seal. I've had to change my rear axle shafts out due to leakage. Occurred after playing in some grainy mud. Luckily the dealer changed them out under warranty but now I avoid the deep mud pits. . |
