JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
No hex bolts on door hinges
Old 04-16-2019, 09:52 AM
Brettpep55's Avatar
Default No hex bolts on door hinges
Good afternoon. I went to take my doors of my 2013 JKU Sahara for the first time and realized I do not have the hex bolts on the bottom of any of my doors. Are mine just missing them or what?
Old 04-16-2019, 10:19 AM
resharp001's Avatar
Received 1,815 Likes on 1,585 Posts
Guessing you are not the original owner. I'd figure a previous owner liked to remove the doors a decent bit, and didn't bother to hassle with those nuts every time. I removed those same nuts 6 years ago and never put them back on. Makes it much quicker to remove/remount the doors.
Mopar part #6511744AA should you care to buy some.
https://www.quadratec.com/products/5...waAtC6EALw_wcB
Old 04-16-2019, 11:37 AM
icrashbikes's Avatar
I also never put them on. No problems.
Old 04-16-2019, 03:44 PM
resharp001's Avatar
If you were interested, I'd sell a set of 8 for $25 shipped. $50+ for em seems redonk. I really don't care either way....and someone on here might sell some cheaper. Won't hurt my feelings if they do. If you care, PM me.
Personally, I'd just live like they didn't exist if I were you.
Old 04-17-2019, 04:57 AM
Actually I'd like to ditch the threads entirely. Does anyone make a hinge pin that's just a tapered pin with no threads to rust? Maybe I'll just cut the threaded ends off my hinges..
Old 04-17-2019, 05:00 AM
resharp001's Avatar
At that point, what do they really matter? Why not just paint or coat the threads with something so they don't rust? I don't think I'd want to cut them off, cuz they are essentially a guide to help line the door up IMO. They help me at least.
Old 04-17-2019, 05:08 AM
karls10jk's Avatar
3d printer idea?? You'd just have to tap the hole on the inside but that would be cake. You could even fill the inside with a lightweight epoxy and then tap the epoxy so you don't risk cracking the plastic.
https://www.quadratec.com/products/5...xoC3EQQAvD_BwE
Old 04-17-2019, 07:38 AM
That's a great idea. I'll make those up. The plastic should tap just fine (they will probably just thread right on with the right sized hole), they will be non-marring on the hinge holes, no corrosion worries, and I could pack them with grease to keep water out and protect the hinge threads in the event I ever wanted to use the nuts again. Plus the taper would be whatever makes sense to line them up and slide them in. I like it. I'll make them up. I like the ones in the link too, but I'll try $0.40 worth of PLA before investing $40 in machined stainless.
karls10jk (04-17-2019)
Quick Reply: No hex bolts on door hinges
