I'm looking into the ones from barricade they are $30. Not sure of how accurate they are but if they can get me close it will be good enough.
Originally Posted by dmwil
(Post 4054947)
Is it true you can put the tire guage right on these without taking them off?
Sent from my iPhone using JK-Forum |
I like my Currie E-Z Deflator - http://www.4wd.com/Jeep-Wheels-Jeep-...pn=CURCE-9029E)
I also use the ARB. Never had a problem with screwing up the threads on the core. Does a pretty quick job. I do carry spare valve stems and cores just in case though....
X2 on the Currie...appears to be the same as the ARB only slightly less $$. Makes quick work of airing down, easy to use and keep track of PSI.
Been using the brass style ones from rugged ridge,gets my tires down to 6psi.Works great
Originally Posted by familytime
(Post 4055137)
Originally Posted by MB_Pathfinder
(Post 4055105)
I like my Currie E-Z Deflator - Currie Part CE-9029E - E-Z Tire Deflator - 4 Wheel Drive)
Edit: The Curry just got a boost, as I saw there is free shipping at 4wd Hardware. I'm now leaning that way. $30 is still steep, so I'm waiting to hear back from the brass users to see how accurate and easy to adjust they are. |
3 Attachment(s)
(Post 4055225)
How easy is it to adjust them to a specific pressure and keep them there?
None of the Staun-type deflators, including the Staun itself, can be counted on to keep the adjustment, but there's a simple cure -- a drop of Locktite on the threading. Another interesting option, expensive, but with multiple pressure options - you just push and rotate to set a desired psi. This one has the range of 10, 12, 14, 16, 18 or 20 psi : Attachment 597012 Attachment 597013 Attachment 597014 |
Originally Posted by Tooadvanced
(Post 4054938)
I have the ARB one that pulls the stem. Impossible to lose the stem as you screw on the connector then remove stem so it is trapped inside the tool. I can air all my tires from 30 to 12 psi and someone else's jeep the same before my brother staun type deflates his tires.
Here is a good test for anyone considering getting them (or another brand) https://www.youtube.com/watch?v=9XtZ1QOP9Pg |
